Steve you seem to have lost control of the blues...
A variation on Varigation
Hi Greg, that certainly improved the image.
Thanks Julie, looking forward to seeing your next version (by the way, if you post your image at around 1100 pixels wide, the viewer could see it in its entirety in expanded view (without scrolling), and I think it also permits a higher quality jpeg conversion. Just a suggestion.)
- color-variationb6-jpg (311.19 KiB) Viewed 62411 times
Spectacular Art...
There is so much variation and color in the image..You should be very satisfied. I took some leaves from the plant and compared then to your image. Just outstanding really..
The subtle reds and the veins of both the large multicolored leaf and the small red green ones are really well represented.
Once you solved the mid-tone contrast problem the image really took off. It has a warmth and fullness that I really like...
Congratulations...
Congratulations...
