darken sky - problem
Postby imported_Tanja » Tue Apr 30, 2013 5:38 pm
Next problem...
Attachment one is the inverted and modyfied L-Channel in cm.
Attachment two the result, when copy to ps.
But the not inverted version in cm works.
inverted-l-channel-cm-jpg
inverted-l-channel-cm-jpg (165.09 KiB) Viewed 10066 times
inverted-l-channel-jpg
inverted-l-channel-jpg (186.62 KiB) Viewed 10066 times
Postby imported_Tanja » Tue Apr 30, 2013 5:39 pm
Hi Art,
is this the topaz-version?
Postby imported_artmar » Tue Apr 30, 2013 6:55 pm
Hi Tanja,
Nope. All original ;D
Postby imported_Tanja » Tue Apr 30, 2013 10:35 pm
Hi Art,
but I like what you show me on Topaz.
Hm...for your picture...maybe little bit less cyan and a little bit more contrast only in the area of this large house?
Don't know, if it makes sense.
Maybe you can paint out the cyan in the water with the frequency seperaton.
I think the sky looks great and colors are very powerful. It's not that much to do.
Postby imported_artmar » Tue Apr 30, 2013 10:46 pm
Hi Tanja,
Thanks -- good suggestions. I'll try them
