Hi Tanja,
Did you get the mask from the mask carte? Which mask did you use??
Monterey dock -- Art
Hi Art,
oups, forget which mask it was. Think the k-channel.
Jep, from the card. I don't find masks in the library... Ohh, this is mabe the confusion!
In the library I only found curves. All avaiable masks are on the card. Greg explain in a posting to Jerry, why there is no mask for c, m an y.
Select a mask don't changes anything.
It' only a selection. Everywhere you see white on the mask, a follow change is seen in your picture. All where mask is black, nothing happens and in the greys the effect of your change is not that strong. Darker grey, less effect.
