I got the file downloaded and installed, but have the same problem as LUC, I think. On installation, it never did ask for any password, but did want my serial number. I provided that as requested, and although I've hidden it here, attached is a screenshot of the "about" screen, see "untitled-2.jpg". During installation, got the message shown in "untitled-1.jpg". I selected "continue" and installation seemed to go OK, even received a message at the end that installation was successful.
But, every time I run Curvemeister, it starts but the Curves don't show up and CS4 crashes if you try to click on anything.
Beta 3.0.13 - 64 bit support
I'm having trouble getting pin files to load. At first the beta showed no pin files at all. After re-loading the latest 32 bit version into the 32 bit CS4, the default pin files for Nature and People do now show up in the 64 bit version as well.
But, I can't get the beta to load a new pin file. I've tried a couple of different ones, both of which open in the 32 bit version, but when I try to open them in the 64 bit beta causes CS4 to crash.
Curvemeister will no longer start, as I get a dialog box saying that the beta time period has expired. Tried removing and reinstalling and supplied my registration name and number when prompted. Clicking continue (see attached screenshot) results with a "successful installation", but again it won't run because the beta time period has expired. Also notice that if you check the plugin information for CM from help->plugins it brings up the registration screen with my correct registration number, but it didn't pick up the correct username.
