Curvemeister 3 shipped on Oct 22
Thanks, Mike. I happened to have this open, and the changes are now on the online version of the manual, and *should* be in the next release:
http://curvemeister.com/support/curvemeister3/help/Menus/MenuImageContext.htm
I'll add something about the mouse wheel too.
Ctrl-R is not used for the ribbon control any more, and has been changed (I believe) to reflect this.
BTW - (also not mentioned in the manual) you can reconfigure the shortcut keys any way you want, so if you get a collision, such as the ctrl-F1, you can reassign a key combination of your own choosing.
Hi,
I'm a new user and have downloaded the demo version of Curvemeister 3. My pin pallette does not have individual colors for the pins - they are all blue. When you put the cursor on them, the color is described in text, but you cannot see the actual color. Is there a setting that changes this?
Thanks.
Thanks.
I've heard of this happening occasionally - one common cause of this is to have your video card set to 256 colors, or even 16 colors. To check this, right click on the desktop, select Properties, click the Advanced button, and click on the Settings tab. If this is the case for your system, try setting your video card to 24 or 32 bits.
I'll be moving this to the Curvemeister Bugs board in the near future so that other people will be able to find it.
(I sent this message to sales too but thought I'd try both input venues). My computer with Curvemeister died a couple of weeks ago. I have my 'serial number' for my Curvemeister product but it isn't installed on my new computer. I've also upgraded from Photoshop CS2 to CS3 and the new computer is running Vista. Sooooo, if I purchase the new version and enter my old 'serial number' will I get a whole new version of only and update? I need the whole thing. Hope this makes sense to you - it's starting to confuse me.
Users browsing this forum: No registered users and 57 guests
