Class Access IMPORTANT
This forum is for the 201 Class preview testers and discussion.
Postby ggroess » Mon Nov 03, 2014 5:20 pm
Art,
E-mail me your chosen password and I'll reset it.
You record is there and both Julie and Martin experienced issues with the password...I have some homework to do...
Postby imported_artmar » Mon Nov 03, 2014 5:32 pm
The screen I access asks for username and email address (which aren't accepted because in use), no blank for password (?)
Postby ggroess » Mon Nov 03, 2014 6:31 pm
Correct.
If you send me the password you want I can re-set it.  I can see your user ID on my side.
That will allow you to log-in rather than trying to register.  Once your ID is correct you can click on the link from the class intro page rather than log-in.
Postby imported_Tanja » Wed Nov 05, 2014 9:33 pm
have the same problem, than Art.
No idea how to come in and not really sure, where I have to login.
Try now half an hour. Now I have to go back to work...
Postby ggroess » Thu Nov 06, 2014 3:43 pm
Tanja,
I have set your password to be newpass1.  Please change it when you login successfully.
I tested your ID and login and they work.
Go to Courses>then click on "CM201 advanced" then follow the link for "Already a Member".
This will force you to login and then you will see your links to the class.
Let me know if that works for you
Postby imported_Tanja » Thu Nov 06, 2014 8:35 pm
seems that I'm in!
Is this message on the top of the page a problem?
"Sorry, but you do not have the correct permissions to activate the Woocommerce plugin. Contact the administrator of this site for help on getting the plugin activated."
Afraid to change the password. As I try yesterday, I failed at the same point.
A notice tell me to click "OK"-button, but there is only the button for "Update Profile", which not works yesterday.
Greetings from Tanja
Postby ggroess » Thu Nov 06, 2014 8:48 pm
You can leave the Password.
We are most likely going to be changing the entire Login process shortly...just clear the WooCommerce meassage.
Postby imported_Tanja » Thu Nov 06, 2014 8:58 pm
Perfect! Was a - in german "nervöses Wrack" - yesterday, after trying to get in ;-)
