red to black "Bommel"
Postby ggroess » Wed May 01, 2013 1:23 pm
Are you sure you ahve the full sized image I was not able to re-create teh noise you are getting on the full sized image.
See shots 1-2 below.
capture-jpg-33
capture-jpg-33 (196.9 KiB) Viewed 10069 times
capture2-jpg-13
capture2-jpg-13 (241.79 KiB) Viewed 10069 times
Postby imported_Tanja » Wed May 01, 2013 6:13 pm
I think so. 1024x768, 300ppi.
Hm, try your curves and look the same.
Have to look snooker now and then try around again.
Postby imported_Tanja » Wed May 01, 2013 8:29 pm
Hm...no. Still there. Even with soft curves on the mask.
Did anybody else here has the same problem?
untitled-5-jpg
untitled-5-jpg (42.93 KiB) Viewed 10069 times
Postby ggroess » Wed May 01, 2013 11:06 pm
You have the wrong image...
See the link below the image on the screen.
capture-jpg-32
capture-jpg-32 (89.12 KiB) Viewed 10069 times
Postby imported_Tanja » Wed May 01, 2013 11:32 pm
Ahh, alright! Now it works!
My one was from the zip-file of this week, but I found the bigger on in the material for week 5.
untitled-6-jpg
untitled-6-jpg (309.84 KiB) Viewed 10069 times
