Thread for all technical problems
Daniel Zuck
Postby Daniel Zuck » Wed Apr 10, 2013 5:29 pm
Greg:
It won't dock no matter what I do.  The curves grid is constantly floating.
dan
Daniel Zuck
Postby Daniel Zuck » Wed Apr 10, 2013 5:45 pm
Greg:
Has this program been debugged?
Daniel Zuck
Postby Daniel Zuck » Wed Apr 10, 2013 8:02 pm
Greg:
I've clicked on the frame and tried to move it over and it still won't dock.  Is this docking maneuver good for all versions of windows?
dan
Postby imported_Tanja » Wed Apr 10, 2013 8:18 pm
Hi Dan,
it's a little bit tricky. I tried out and needs some time, til it's want to dock. But it works.
Daniel Zuck
Postby Daniel Zuck » Wed Apr 10, 2013 8:58 pm
Tanja:
what's the secret?
dan
Postby imported_Tanja » Wed Apr 10, 2013 9:12 pm
Hi Dan,
I don't know. Don't want to try that again. Needs some time.
There is no problem to dock the window above, but I don't want it there.
Suddenly it docks on the right side.
Postby ggroess » Wed Apr 10, 2013 10:44 pm
Push it over to the edge until the blue box expands along the whole edge and then let it go....
That is all it should take.
Daniel Zuck
Postby Daniel Zuck » Thu Apr 11, 2013 9:45 am
Greg and Tanya:
Okay, what I did was try to 'bounce' the blue window a couple of times off the right side of the image working window and it worked.  Now its docked.  It doesn't work automatically, it is a bit tricky.  Thanks.
dan
Postby ggroess » Thu Apr 11, 2013 11:14 am
Glad you kept trying...
There is a beta team that works on all major releases of the plugin.  The problem you described is more of a behavior of the window shell rather than the contents of that shell.
Postby imported_artmar » Thu Apr 11, 2013 1:46 pm
Hello All,
When I go into CMYK space, at the bottom of the Curves Window I see two sliders for GCR and Fade, but no GCR control option to choose various blacks as shown in this week's materials. Does anyone know how I can see this?
Thanks,
