Anyone using Creative Cloud?
Mitch
Postby Mitch » Mon Nov 04, 2013 1:44 am
I didn't have an error.  it seemed to install correctly, but CM doesn't appear in filters.
Postby ggroess » Mon Nov 04, 2013 2:09 am
Do a quick file search for "Curve*.8BF" you should find it as shown below:
C:Program FilesCurvemeister.comCurvemeister3-64
Copy the Curvemeister3.8BF file and paste it into the CC version of this folder:
C:Program FilesAdobeAdobe Photoshop CS6 (64 Bit)Plug-insFilters  (This is the CS6 version of the folder)
Should show up when you re-start PSCC
Mitch
Postby Mitch » Mon Nov 04, 2013 2:31 am
That worked.  Thanks Greg!
Postby ggroess » Mon Nov 04, 2013 3:14 am
Awesome...
Happy Curving!
Mitch
Postby Mitch » Mon Nov 04, 2013 4:31 am
Oops!  Now CM has disappeared from the filters.
Postby ggroess » Mon Nov 04, 2013 9:37 pm
Mitch,
Try this folder
C:Program FilesAdobeAdobe Photoshop CS6 (64 Bit)RequiredPlug-insFilters  (This is the CS6 version of the folder)
See if it sticks there.
Mitch
Postby Mitch » Mon Nov 04, 2013 9:58 pm
Should I look for the CC version of this folder?
Postby ggroess » Tue Nov 05, 2013 1:00 am
Yes you should find the same folder under CC.
That is my understanding right now...
I do not have CC so I am guessing a bit here.
Mitch
Postby Mitch » Tue Nov 05, 2013 2:19 am
I tried that and it didn't work.  Any other ideas?
Doug.S
Postby Doug.S » Tue Nov 05, 2013 3:47 am
After doing CC trial (see earlier post above) I decided to sign up with Adobe and all is running well an CM still doing fine, no glitches.
Doug
PS I don't like the subscription concept but price is OK now and updates/new stuff installs OK and CM still humming along.
I use both x32 and x64 as my scanner still only has a 32bit driver...otherwise mainly run x64 on win7pro.
Users browsing this forum: No registered users and 57 guests
