Rhonda Week 3 Cathedral 1
Postby sjordan93436 » Wed Oct 27, 2010 6:08 pm
BTW, I took your 6 pointed star (double triangle) diagram that showed the 6 colors.  I added notation from + a, +b, -a, -b
Next I will do the same for the conversion table.
I think that would be helpful for newbies.
Postby ggroess » Wed Oct 27, 2010 7:11 pm
Indeed...Post it if you like...
I am re-writing some of the week 1 materials...
Postby mikemeister_admin » Wed Oct 27, 2010 8:30 pm
Yes, please post it!
I found this neat color mixer tool--doesn't tell you about opposites, but does give you color numbers for almost any color or combination:
http://www.colortools.net/color_picker_extended.html
I'm not sure the chart shows the entire spectrum.  The colors on the right seem cut off--no true green or yellow.
Postby ggroess » Wed Oct 27, 2010 8:33 pm
Color Pickers use a color space and you might be getting clipped by the default space they use for the picker...
Each space has it's own Gamut...
