Jean,
It sounds like Mike is going to have to connect to your PC and help you out. I'll again forward this to him; his notification systems are giving him some fits lately so he asked me to make sure I kept sending him anything that he has not responded to ...So this is one I'll forward to him...
curvemeister 3.2 crash photoshop cs5 32 bits
I vound what is msvcrt10.dll
http://smokeymountaingallery.com/Blog/Photographers_desk.htm
Error using Photoshop 6.0 filters with CS3
After installing Photoshop CS3 I copied my old filter files from my installation of Photshop 6.0 to Photoshop CS3, ( Program FilesAdobeAdobe Photoshop CS3Plug-InsFiltersAdded Filters),The next time I opened Photpshop CS3 the program would not run. I got an error message that said the file Msvcrt10.dll could not be found.
I did a search for the file and found it in c:program filesadobePhotoshop 6.0. After I copied this file to the install directory for CS3 everything works fine now. Here is a copy of the file if you need to do the same thing:
Download Msvsrt10.dll
Hi,
I'm posting in this thread because it pretty much describes my problem.
I'm using XP SP3, 32 bit. I just installed Photoshop CS5 32-bit and Curvemeister crashes it in spectacular fashion.
First I downloaded 3-3.2.0 and when I tried to install it, I was surprised to discover that there was no checkbox for CS5. (CS5 is six months old now.)
So I checked 'Other' and browsed to the plugin directory, which seemed to work. When I tried to invoke it, however, I got part way through the opening dialog (it defaults to using the wizard) and then--boom!
I uninstalled, reverted to 3-3.0.19, same result. I found this thread, which I realize is a few months old, but I see no resolution other than Mike Russell needs to take remote charge of my computer. Is there a better solution by now? Does Curvemeister support 32-bit CS5 yet?
I find this frustrating because I use (and love) the Curvemeister a lot.
Users browsing this forum: No registered users and 58 guests
