Same pond ,different critter
Postby mikemeister_admin » Fri Jun 11, 2010 3:40 pm
Cropped image.I pushed the blue hard and there's a little spillover in the background that I might dial back.GregM
Image2 background selected  and toned down with cmyk in Cm.
abugaleaf4-jpg
abugaleaf4-jpg (292.3 KiB) Viewed 5453 times
abugaleaf-acv
(66 Bytes) Downloaded 721 times
abugaleaf2-acv
(86 Bytes) Downloaded 690 times
abugaleaf3-acv
(54 Bytes) Downloaded 678 times
abugaleaf4-copy2-jpg
abugaleaf4-copy2-jpg (292.06 KiB) Viewed 5453 times
Postby ggroess » Sat Jun 12, 2010 8:43 pm
Another interesting challenge which was not so easy as it first looked! I did the main tweaking in lab to increase the saturation and improve detail in the leaf while not darkening the insect too much and darkening the light coloured background.  I also tried to give the leaf a translucent surreal look. I added a bit of red in rgb to warm the tone. The picture can be improved by cropping.  Thanks for letting me have a go, I enjoyed the challenge!
Kind Regards
Chris
Chris,
The flat part of your L  curve is making the background look a bit flat.  See if you can adjust it a bit to take the "solarized look" out of the rock in the background
