flower vendor
Postby mikemeister_admin » Sat Aug 01, 2009 1:24 am
seven
I think it might be easier just to start all over.GregM
londonflower-jpg-lab-acv-2
(82 Bytes) Downloaded 1447 times
Postby ggroess » Sat Aug 01, 2009 2:08 am
I'll try taking a look at this over the weekend...
Postby ggroess » Tue Aug 04, 2009 6:01 pm
I started to apply these to the original image and found myself reeling from the changes...
I'm fairly certain you did not want to do what resulted to the image.
The closest you got was the first LAB ACV file.  After that it just went to heck in a hand-basket. most definitely not what you posted to the web.
I think your last suggestion might be the best.
It would help me if you stated the goals first so I can see what you are trying to improve.  if your goal is to improve the image overall and just try new things to see how they effect the image I'm all for that as well...Just let me know.
Postby mikemeister_admin » Wed Aug 05, 2009 2:32 am
Greg,don't spend anymore time on this image.This was just a total mess.Thanks,GregM
Postby ggroess » Wed Aug 05, 2009 3:12 am
not a problem...I can move on...
