Thanks, Luc. That gives me a clue that CurveCtl3.ocx has a problem, and perhaps is not installed correctly.
There are three files installed in the filter folder, instead of one. This is due to the simpler logic of the new installer, which had to be re-implemented for 64 bit.
Another thing you could do that would be helpful would be to go into CS4 and selecte Help>About Plugin>Curvemeister 3 and see if the about box comes up, with version 3.0.13.
Beta 3.0.13 - 64 bit support
Yes it does I had checked before.
But I see only two files with dates of today or yesterday. See screen capture attached.
Luc.
Re deployment problems with 64 bit.
I've made an installer for the test.exe program, and added another program called test0.
http://curvemeister.com/downloads/cm3_beta/CM_test64.zip
Start>All Programs>Curvemeister.com>CM_test64>test0 brings up a simple dialog with the word "Success" in it. Test brings up a window containing a curve control.
If one or both of these programs works correctly, this will provide some insight on why Curvemeister3 is crashing on some 64 bit systems.
I fixed an installer problem that affected both Curvemeister and the test programs. CurveCtl3.ocx was not being registered, which caused Curvemeister to get an error during initialization.
Please download CM_64_3.0.13b.zip from the beta area and give it a try.
