I did the mask in PS4 I am afraid that the CM mask pallet is over my head at this point.
Gary
Let's Get the Party Started.....
A slope to the saturation and an s curveto the brightness in HSB,then sharpening.I wanted four colors to the lighthouse and some detail to the sea.My first image was a portrait crop with the lghthse in upper left corner and the seagrasses lower right but I ran out of pixels so I applied the corrections to the entire image. GregM
For a quick and dirty solution try the pin files...There is a pin in the "nature" tab called Glenco Sky...see screen shot
Drag the pin up to the sky and drag it around until you find a sky color you like.
If you are in LAB you might want to set a solid neutral first so the rest of the image does not get too messed up.
Let me know how that works out....
