ok...operator error or I D 1 0 T error. but nothing happens on my vista system....
I open a file in PS, Open CM and run the Exe right?? no change...
I can select a point on the curve and drag it off the grid just fine...but I cannot select it and delete it... the reset from the right click menu does remove the points from the curve...
XP testing in the morning.
Delete appears to not remove a point from the curve
Thanks for the clarification, Greg.
TestCurveCtrl.exe runs by itself. It runs the curve control, independent of Curvemeister, to see if the bug is related to curvemeister.
If I understand correctly, the curve points can be dragged off the curve, but selecting the point and pressing the DEL key does not work?
