Photoshop CS4 and 64 bit support
Just a status. I've set up the necessary hardware and software, and made substantial progress with porting some of the components of Curvemeister over to 64 bit. The process is partly clerical - changing things to get them to compile under the new compiler, and a few head scratchers: functions that have been changed in ways that require significant changes.
I cant' give a definitive date for completion - I had estimated two weeks ago, but other items, including the recent beta releases, needed to be cleared up before I could really proceed with the new 64 bit code line.
Here's hoping for a 64 bit beta release in the next two weeks.
Thank you very much for the heads up.
I had an unrelated question.
Without revealing the secret of Curvemeister, is there a way for you to add some unsharp mask option on the L* channel while in CM.
I am not sure if internally CM goes to Lab* and back or not.
I was just thinking that it is one of the think that is nice to do in Lab*.
Luc.
Luc.
