Keep the Ribbon, or lose it?
The ribbon is staying.
I've just grabbed 3.0.0.8 and the ribbon's Home panel now looks a lot better. Further thoughts:
* the View panel should be second from left, and should have a hand tool, sampler and magnifying glass (i.e. like the Tools panel on the View ribbon)
* View Options should be next
* Remove the Curves panel - surely those are just settings switches that aren't often used? The space could be better used I suspect (not sure what with yet!)
* does it need to be 3 layers tall? Is 2 a possiblity? There's lots of room horizontally, even on my screen, but vertical space is at a premium.
It's looking much better already, much less intimidating. Obviously the other panels, other than Home, need a bit of work yet.
