Benny c1s3 Example 3
Postby mikemeister_admin » Fri Jun 01, 2007 12:42 pm
Worked in LAB. Adjusted threshold by dragging the rightside of the L curve in a couple of squares.
Then adjusted L curve further to steepen the curve that covered the main centre water drop.
This adjustment seems to have particularly brought out the texture underneath the lower-right water drop. Almost looks like a rough skin texture which I like.
Benny
Postby ggroess » Sat Jun 02, 2007 9:14 pm
Good job,
You can take it further if you want and up the saturation...it is not required...
Did you find the spider in the image??
Postby mikemeister_admin » Sat Jun 02, 2007 9:46 pm
Yes, now that you have pointed it out :)
