ganna c1s2 example3
Postby imported_ganna » Sun May 27, 2007 5:35 pm
Thanks so much for this wonderful forum. I'm learning a lot from reading the the other participants' messages. Greg, I understand that I am not restricted to CM only but can use other functions in PS also
Here, I first did Luminosity Masking (Bob Johnson of Earthbound light.. where I first read of CM ie curves on steroids!)
That brought the detail out of the shadows. I am unfamiliar with the real place in the image; not sure what it really looks like(colour wise) but I first used the LAB mode-> thresholding and saturated. I saved then opened in the RGB where I try to get more green in the trees. My image might be too light, but here it is. Finally it was sharpened with Smart sharpen.
Cheers, Ganna
Postby ggroess » Sun May 27, 2007 8:50 pm
The place in question is Bryce Canyon in the state of Utah USA.  It is a very striking landscape and the orange colors are quite vibrant.  I would say that you image is light yes...but a worthy rendition none the less.
There is a bit more drama in the original.
