Week 3 example 3 and 4
Postby mikemeister_admin » Fri Jun 22, 2007 4:00 am
the next two ...Abby
Postby -default » Sat Jun 23, 2007 7:05 am
You've made a significant improvement in both of these images.  Try making things darker, overall, in order to get more detail in the brightest areas.  In particular the sand in the second image is still a bit washed out.  This is an idea place to make the curve steeper at the bright end, to get more detail.
