example 1 week 4 infinitech
Postby mikemeister_admin » Sat Jul 28, 2007 3:15 pm
I followed the intructions, created 4 hue clocks all along the feathers, and changed the blue channel in RGB, seems a bit greenish to me; don't know though. I set up to saturation a bit.
Postby -default » Sat Aug 04, 2007 11:13 am
Yes, it is a little greenish.  For this example, try moving the black end of the blue curve inward.  This will inject yellow into the darker areas of the feathers, which are a bit on the blue side.  Move the endpoint until you get the hue clocks very close to one another.  Avoid adding any flat spots to the curve.  In most cases this robs detail.  If the shadows look green, move the black end of the green curve in a bit to even out the hue for the lightest and darkest areas.
