I need to go back to the manual, didn't quite know what i was doing as far as seeing the blue in the clocks and how to get rid of it, but did what seemed to work for me, and am I judging it right.
I want to go back to your answers for week 3 and redo the examples, i think that will help me a lot.
It seems that the trick is to try "read" the picture as to what are the problems and what needs to be braught out of it, and read the manual over many times.
donberl Week4 Example1
That is indeed the "trick" There are some areas on the hawk that are blue, deep down in the darker feathers.
You could try to get at them in RGB.
One thing you might have to do is make the CM window really big so you can work in the darkest parts with enough room to see what you are doing.
I always look over the image and make a mental list of what I want to fix...I usually run the Hue clock over the image to see if there are hidden colors, like the blue in the feathers. I then start fixing the things that have a broad impact then I get specific. I usually have to stop myself...I tend to over adjust...
I always remind myself...only retouch or correct the image enough to hide the flaw...don't make it worse...
