week 2 Self
Postby mikemeister_admin » Fri Jul 20, 2007 1:57 pm
I add a lizard tail to bring back details of the white pole.
Postby mikemeister_admin » Fri Jul 20, 2007 2:01 pm
Sorry, the heading "Week 2 Self" should be "Week 3 Self".
Postby ggroess » Fri Jul 20, 2007 8:07 pm
not a problem....
It looks a bit yellow...Where did you pin the neutral??  Mostly curious...
Postby mikemeister_admin » Sat Jul 21, 2007 1:38 am
I set the neutral on the bright side of the white pole. Where would you suggest to set the neutral in order to remove the yellow cast.
Postby ggroess » Sat Jul 21, 2007 2:03 pm
While it is a bit subjective and the tone of the image is important you could benefit from a "neutral thresholding" for lack of a better term.
What I do is drag the neutral around the image and watch the color cast until I find one that looks as good or better than the current one.
Below are two examples of areas I found that can change the tone of the image while still keeping the warmth.
Postby mikemeister_admin » Sun Jul 22, 2007 12:41 pm
Greg wrote :-
>>What I do is drag the neutral around the image and watch the color cast until I find one that looks as good or better than the current one.>>
That's a very useful way of finding an appropriate neutral by dragging around. Thanks a lot Greg :D
Postby ggroess » Sun Jul 22, 2007 1:02 pm
Glad I could be of help
Users browsing this forum: No registered users and 54 guests
