Fruit vendor,I really am having a hard time with this fruit picture.
I cannot get my fruit to come out nice
Week 3,Ex.2-fruit vendor
You're getting it. For this image, we're really concerned with changing the neutrals rather than improving the fruit, though the fruit will be improved a little as a side effect of fixing the neutrals.
Your image has reduced the original green cast substantially, which is good progress. Now there is a yellow cast, which means you need to add a bit of blue (pulling a point up on your blue curve. The video shows how to do this in both RGB and Lab so you may want to check that out first before tackling this one again.
