This week the lesson touches on Color By The Numbers.
Attached to this posting you will find links to a few goodies for you to try out.
The first is a PDF document and an image.
The PDF is a walk through for color correction by the numbers using Curvemeister.
The PDF is here:
www.curvemeister.com/video/greg/color_correction_by_the_numbers.pdf
The image is here.
www.curvemeister.com/video/greg/dan_and_friend.JPG Right Click and save link as should download it.
Next on the list is a short video of another color by the numbers correction and the image for you to use.
www.curvemeister.com/video/greg/rgb_btn.swf
and the image:
www.curvemeister.com/video/greg/Dan-Hat.jpg Right Click and save link as should download it.
Happy Curving!
A Curvemeister Look At Color By The Numbers
I think the key to this sometimes is the realization that you need to select meaningful shadows, highlights and a possible neutral.
The brightest white is not necessarily the correct highlight setting. If it is meaningless, it could be doing more to hurt you. The main subject of a portrait is the most important part...I know ...But we sometimes forget the reason we are mucking around in the images in the first place.
If you are satisfied with the choices you need not defend them. If your subject is not satisfied you'll need to defend them.
Users browsing this forum: Baidu [Spider] and 1 guest
