j2e4a8n
Postby j2e4a8n » Wed Oct 22, 2008 1:23 pm
Postby ggroess » Thu Oct 23, 2008 6:50 pm
Jean,
Did you do a Shadow highlight neutral on this image??  seems like there should be more contrast in the image...
j2e4a8n
Postby j2e4a8n » Thu Oct 23, 2008 10:17 pm
No.  For the sake of the course, I use only curvemeister.
I sharpen some time the end result with  ,7 radius  and 100% amount.
Postby ggroess » Thu Oct 23, 2008 11:21 pm
you can set shadow highlight and neutral in CM while you are adjusting the other parts as well.
j2e4a8n
Postby j2e4a8n » Fri Oct 24, 2008 2:59 pm
I was meaning the shadow-higlight filter in photoshop.
Language . . .  and images . . . are very often misleading the meaning. Well, lets say for myself. But . . .  I still thing it is a humanitarian problem too.
Postby ggroess » Sat Oct 25, 2008 1:57 am
Jean,
I certainly do not want the language to be an issue..I hope I have not mis-read your intentions...
