Curvemeister Version and Pins
This the forum board for The Curvemeister 101 class starting August 25th 2013
tmanley
Postby tmanley » Fri Oct 11, 2013 3:46 pm
I have checked for updates and there are none available.  I'm using 3.8.1.0.64 bit.  The only pins I have are Nature (15) and People (9).  I'm very excited about the Zone System pins and would love to be able to use those.  I can't find them on the website under the Curvemeister Pin Collection either.  Are they available somewhere else?
Thanks!
Tina
Postby ggroess » Sat Oct 12, 2013 11:10 am
Tina,
on the forum...
Right below your Avatar Icon and name there is a line of Links...
Go to downloads >Customer downloads> and you will see the 3.8.2 build for PS both 64 and 32 bits.
This version should install the Pins you are looking for as well.
If it does not...After you install we can work our way through getting them set up for you.
tmanley
Postby tmanley » Sat Oct 12, 2013 1:21 pm
Got it!  Thanks, Greg.  I can't wait to try the Zone pins!
Tina
