If I remember, there is a formula to trace a curve wich approximate a zig zag ing curve. They use it in finance and else.
That would be a nice feature. I think . . .
smoth curve
Yes, this feature could be added to Curvemeister. I would need to be convinced that it is actually useful in a practical sense. Each of those corners will show up as banding in a normal image.
Photoshop can do this, by the way, by clicking on the curve's pencil icon and then shift-clicking on the curve to define straight lines. Here's a gradient, showing the banded effect from even a fairly mild set of straight lines.
Yes but if that is true, then I lose correction that I might just want a sharp bend in the curve for.
I would be back to an average correction rather than my hard fought dog leg. It might smooth the middle of the curve quite nicely but at the extreme ends I might just want a nice sharp bend.
In that case you just dont use it ;-)
