not lego, not skin . . . Paint!
Curvemeister pins are like a memory bank for colors. Discuss techniques and applications for pins. Find out about new pin files here!
j2e4a8n
Postby j2e4a8n » Tue Sep 09, 2008 10:07 pm
What is clipped with this text?
Is this OK?
And by the way, what is the utility difference between pins and swatches?
Postby -default » Tue Sep 09, 2008 10:50 pm
I'd need to look in more detail (working on the installer checker right now).  One thing that I notice is that there are two tabs separating some of the columns, and it should be one tab.
Swatches was the old name for pins, internal to Curvemeister.
j2e4a8n
Postby j2e4a8n » Wed Sep 10, 2008 12:52 pm
Should I put my file in the swatches folder too?
Postby -default » Wed Sep 10, 2008 4:23 pm
That will work.  You can also right click on the pin pallete and load the file directly.
Does tthis mean that Curvemeister is now working on your system?  If this is the case, then perhaps I can stop working on the "CmChecker" program and help with the pin file.
j2e4a8n
Postby j2e4a8n » Wed Sep 10, 2008 5:47 pm
It does work.
Although a file describing all the keys setted  in the registry and the tree of the installation would be fine for everyone and every software.
By the way, yours, is very good in my opinion.
I used the free 'Unlocker from a french Cedrick Collomb' to get rid of the folders.
http://ccollomb.free.fr/unlocker/unlocker1.8.7.exe
Postby -default » Wed Sep 10, 2008 6:27 pm
Thanks for the reference to the unlocker utility, and for sorting out the problem.
I'll postpone the CmChecker utility for the time being and take a look at loading your pin file.
Postby -default » Wed Sep 10, 2008 6:36 pm
I loaded the pin file, and all 20 pins appear in the pin palette.  Now the interesting part of the experiment begins, which is to use them to improve reproductions of oil paintings.
Return to “Color pinning”
