Help! I can't get CM installed on my new machine w CS5 64. I get a beta expiration notice. Also it can't find the plug-ins folder, which I manually pointed it too. I tried using the Photoshop internal update for the plugins, but that didn't work. At the end I had no CM at all!
DOH! Just read about the 3.3.3 and it solved the problem. Thanks! Recommend you update the update links.
CM 64 3.2.3 intall on CS5 64 getting beta expiration
