I have just submitted this via the ticketing system, but just to give everyone a heads-up - version 3.3.4 will save - but cannot load - curve files.
I'm running Photoshop CS5 on Windows 7. CM 3.3.4 is installed on CS5 64-bit, and CM 3.2.5 is installed on CS5 32-bit. 3.2.5 can open acv files saved by v3.3.4, but something is obviously making 3.3.4 a bit unhappy.
I'm assuming that the 32-bit version of 3.3.4 is ok - but I don't have it installed to check. If anybody else could, that would be really helpful.
3.3.4 (64-bit) cannot open ACV files
I'm still in the process of ramping up the Visual Studio 2010 development tools. Hopefully, I'll be able to make Curvemeister significantly smaller, since it will leverage the dll's that are shipped with Windows, instead of the third party software that I use to support the ribbon and docking panels.
The big question is whether windows 2000 is going to be supported by the new environment - if not I back off to 2008.
