desaturated colors
j2e4a8n
Postby j2e4a8n » Sat Sep 12, 2009 5:37 pm
Hi Mike,
In Lab 64 bits.  When I have to really crank the white side of an image, lets say to 33%  and up of the x axis, the colors desaturate completely and I cant boost them with the gamma feature.
Jean
Postby -default » Tue Sep 29, 2009 10:05 am
There can be a number of causes of this.  The main one is mathematical - if the colors are brighter, then it is not possible to saturate them beyond a certain point without changing the hue.
Lab, alone among the color spaces, will attempt to give a significant hue and saturation to a color at near maximum brightness, but it is nowhere near as saturated as a true painter's color would be.
The solution is to make the color somewhat darker, using perhaps a Lightness or inverted K mask, and then increase the saturation.
BTW - I hope that the pin problem that you mentioned some time ago is no longer occurring on your system.
