selecting a part of an image, running cm amd moving the mouse into the selected area crashes cm with an error message like 'DVPDoc::ReadPixelsFromLevel: readPixelsProc error: PARM'
wnick
curvemeister and selected regions
the error happens to all of my pictures - if I try to edit only a part of the image as soon as I move the mousecursor in the non masked area in the cm window it crashes with the above error message.
This happens in PS 6.01 and PSE 6 with cm 3.0.8.0 with all 16bit images. 8 bit images are ok.
I re-installed cm but same as above:-(
wnick
wnick
The 16 bit selection problem has been fixed, and I apologize for the delay. I have a rather difficult bug that required some internal changes, unrelated to the selection problem, that is holding up the beta release.
I may have to reluctantly put that problem aside so that I can address this and and other problems. Look for a release in the next day or two.
