Is it possible to exit CM and have a mask loaded?
Bulldoggie
Postby Bulldoggie » Tue Aug 26, 2008 4:52 am
I was working on an image tonight where the Hue mask was almost perfect for what I needed. But I couldn't figure out how to exit CM with the mask showing up as a mask in the PS layer to do the extra work on it (mostly making sure the B/W conversion was correct all over). That mask, after the cleanup work using PS tools, would have been useful for other layers.
Is there anyway to get CM to load the mask as an alpha channel (or something equivalent)?
Postby -default » Tue Aug 26, 2008 6:04 am
Right now you can copy the mask to the clipboard, then alt click on the layer mask in Photoshop and paste into it.
Bulldoggie
Postby Bulldoggie » Tue Aug 26, 2008 11:15 pm
Cool! That will do the trick.
Glossy
Postby Glossy » Sat Aug 08, 2009 10:24 am
Thanks for the tipp. It works.
But not always (for me):
If i the mask invert (over function invert) works it not. Then not the inverse mask is copied, but the normal mask.
It functions with me only if I invert the mask with the mask curve.
Greetings Wolfgang
Excuse my bad english.
Postby -default » Sat Sep 26, 2009 8:53 am
Thanks for the info.  I'll add this to the bug list.
