A new 64 bit beta is available (for 64 bit CS4 only):
This version fixes a problem with the version 3.0.14 installer getting an error -8. I'm eager to know whether this fixes the problem. Please pose a note here to let me know if you are able to install this version.
My thanks to all of you who waited so patiently for this release.
64 bit version 3.0.15
I'm pretty sure I have a handle on the "failure to install" problem reported by Klaus and at least one other person. The Curvemeister3.8bf file is copied to a fixed location:
C:Program FilesAdobeAdobe Photoshop CS4 (64 Bit)Plug-insFilters
If this matches the location of your Photoshop installation, as is the case on my system and others, Photoshop will find Curvemeister. Otherwise Curvemeister will not be visible to Photoshop. As a workaround, copy Curvemeister3.8bf manually from the above folder to the correct location for your Photoshop installation.
Look for a new version, v3.0.15b, that fixes this problem.
