I have been using bridge and PS6 64 bit and its just getting slower and slower
Its ok when I get into PS but getting there is taking forever
Opening, sorting, applying, meta data, anything in bridge is slow or freezing.
Its driving me crazy
I do have a lot of images but have been trying to keep them in smallish folders
I am wondering if my system is just not up to it any longer and would appreciate any suggestions anyone may have
I have windows 7 home premium
Processor Intel Core (TM) 2 Quad CPU Q9400 @ 2.66GHz @.67 GHz
8.00 GB Ram
64 bit operating system
Bridge and PS and windows are all up to date
I have two internal drives one with just the images and the other with everything else
I have recently started using raw instead of jpg. Could the larger file size be causing any problems?
thanks
bridge is so slow
You system is not slow...you are very close to what I use. it's not the fastest but it's not slow.
Have you tried compacting the Cache? go to Edit> Preferences> then choose the Cache tab and compact or purge the cache. Purging it will remove stored previews and you will experience a slower preview load until they are rebuild. try compacting it first and see if your perfomance gets better.
RAW should not slow this down. Bridge is a database it is simply a pile of links to the XML and image data.
the other day bridge just ground to a complete stop
after a quick trip to the repair shop I have discovered the problem was the drive all my images are on
they have done a bit of a repair and I am making sure I have everything backed up before the drive just stops forever
thanks for the quick reply
